Cesium for Unity 1.26.1
CesiumForUnity.CesiumAzureMapsRasterOverlay Class Reference
A raster overlay that directly accesses Azure Maps. More...
Inheritance diagram for CesiumForUnity.CesiumAzureMapsRasterOverlay:
Protected Member Functions
Properties
string key [get, set]
 The Azure Maps subscription key to use.
string apiVersion [get, set]
 The version number of Azure Maps API.
AzureMapsTilesetId tilesetId [get, set]
 The tileset ID to use.
string language [get, set]
 The language in which search results should be returned.
string view [get, set]
 The View parameter (also called the "user region" parameter) allows you to show the correct maps for a certain country/region for geopolitically disputed regions.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
If you're using Azure Maps via Cesium ion, use the CesiumIonRasterOverlay component instead.
Definition at line 91 of file CesiumAzureMapsRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumAzureMapsRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumAzureMapsRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ apiVersion
string CesiumForUnity.CesiumAzureMapsRasterOverlay.apiVersion
getset
Definition at line 113 of file CesiumAzureMapsRasterOverlay.cs.
◆ key
string CesiumForUnity.CesiumAzureMapsRasterOverlay.key
getset
Definition at line 99 of file CesiumAzureMapsRasterOverlay.cs.
◆ language
string CesiumForUnity.CesiumAzureMapsRasterOverlay.language
getset
This should be one of the supported IETF language tags, case-insensitive. When data in the specified language is not available for a specific field, default language is used.
Definition at line 148 of file CesiumAzureMapsRasterOverlay.cs.
◆ tilesetId
AzureMapsTilesetId CesiumForUnity.CesiumAzureMapsRasterOverlay.tilesetId
getset
Definition at line 129 of file CesiumAzureMapsRasterOverlay.cs.
◆ view
string CesiumForUnity.CesiumAzureMapsRasterOverlay.view
getset
Different countries/regions have different views of such regions, and the View parameter allows your application to comply with the view required by the country/region your application will be serving. By default, the View parameter is set to "Unified" even if you haven't defined it in the request. It is your responsibility to determine the location of your users, and then set the View parameter correctly for that location. Alternatively, you have the option to set 'View=Auto', which will return the map data based on the IP address of the request. The View parameter in Azure Maps must be used in compliance with applicable laws, including those regarding mapping, of the country/region where maps, images and other data and third party content that you are authorized to access via Azure Maps is made available. Example: view=IN.
Definition at line 180 of file CesiumAzureMapsRasterOverlay.cs.
