cesium-native 0.67.0
Statistics about property values. More...
#include <CesiumTilesetJson/PropertyStatistics.h>
| std::optional< CesiumUtility::JsonValue > | min |
The minimum property value occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | max |
The maximum property value occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | mean |
The arithmetic mean of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the mean of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | median |
The median of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the median of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | standardDeviation |
The standard deviation of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the standard deviation of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | variance |
The variance of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the variance of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | sum |
The sum of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the sum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::unordered_map< std::string, CesiumUtility::JsonValue > | occurrences |
A dictionary, where each key corresponds to an enum name and each value is the number of occurrences of that enum. Only applicable when type is ENUM. For fixed-length arrays, this is an array of component-wise occurrences. | |
| static constexpr const char * | TypeName = "PropertyStatistics" |
Definition at line 17 of file PropertyStatistics.h.
Definition at line 94 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::max |
Definition at line 38 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::mean |
Definition at line 46 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::median |
Definition at line 54 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::min |
Definition at line 30 of file PropertyStatistics.h.
| std::unordered_map<std::string, CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::occurrences |
Definition at line 86 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::standardDeviation |
Definition at line 62 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::sum |
Definition at line 78 of file PropertyStatistics.h.
Definition at line 22 of file PropertyStatistics.h.
| std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::PropertyStatistics::variance |
Definition at line 70 of file PropertyStatistics.h.
