CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue Struct Referencefinal
Extension3dTilesContentConditional Dimensions Value. More...
#include <CesiumTilesetJson/Extension3dTilesContentConditionalDimensionsValue.h>
Inheritance diagram for CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue:
std::string name
 The name of the property that is used for defining the condition, to be used as one of the keys in the conditional content array items.
std::vector< CesiumUtility::JsonValue > keySet
 The set of all values that appear in any condition.
int64_t CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue::getSizeBytes ( ) const
Definition at line 41 of file Extension3dTilesContentConditionalDimensionsValue.h.
◆ keySet
std::vector<CesiumUtility::JsonValue> CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue::keySet
Definition at line 33 of file Extension3dTilesContentConditionalDimensionsValue.h.
◆ name
std::string CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue::name
Definition at line 28 of file Extension3dTilesContentConditionalDimensionsValue.h.
const char* CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue::TypeName
Initial value:
"Extension3dTilesContentConditionalDimensionsValue"
Definition at line 21 of file Extension3dTilesContentConditionalDimensionsValue.h.
