CesiumGltf::VertexAttributeSemantics Struct Reference
The standard glTF vertex attribute semantics from the specification plus additional vertex attribute semantics from extensions. More...
#include <CesiumGltf/VertexAttributeSemantics.h>
static const std::string POSITION
 Unitless XYZ vertex positions.
static const std::string NORMAL
 Normalized XYZ vertex normals.
static const std::string TANGENT
 XYZW vertex tangents where the XYZ portion is normalized, and the W component is a sign value (-1 or +1) indicating handedness of the tangent basis.
static const std::array< std::string, 8 > TEXCOORD_n
 ST texture coordinates.
static const std::array< std::string, 8 > COLOR_n
 RGB or RGBA vertex color linear multiplier.
static const std::array< std::string, 8 > JOINTS_n
 The indices of the joints from the corresponding skin.joints array that affect the vertex.
static const std::array< std::string, 8 > WEIGHTS_n
 The weights indicating how strongly the joint influences the vertex.
static const std::array< std::string, 8 > FEATURE_ID_n
 Feature IDs used by EXT_mesh_features.
Definition at line 12 of file VertexAttributeSemantics.h.
◆ COLOR_n
const std::array<std::string, 8> CesiumGltf::VertexAttributeSemantics::COLOR_n
static
Definition at line 38 of file VertexAttributeSemantics.h.
◆ FEATURE_ID_n
const std::array<std::string, 8> CesiumGltf::VertexAttributeSemantics::FEATURE_ID_n
static
Definition at line 54 of file VertexAttributeSemantics.h.
◆ JOINTS_n
const std::array<std::string, 8> CesiumGltf::VertexAttributeSemantics::JOINTS_n
static
Definition at line 44 of file VertexAttributeSemantics.h.
◆ NORMAL
const std::string CesiumGltf::VertexAttributeSemantics::NORMAL
static
Definition at line 21 of file VertexAttributeSemantics.h.
◆ POSITION
const std::string CesiumGltf::VertexAttributeSemantics::POSITION
static
Definition at line 16 of file VertexAttributeSemantics.h.
◆ TANGENT
const std::string CesiumGltf::VertexAttributeSemantics::TANGENT
static
Definition at line 28 of file VertexAttributeSemantics.h.
◆ TEXCOORD_n
const std::array<std::string, 8> CesiumGltf::VertexAttributeSemantics::TEXCOORD_n
static
Definition at line 33 of file VertexAttributeSemantics.h.
◆ WEIGHTS_n
const std::array<std::string, 8> CesiumGltf::VertexAttributeSemantics::WEIGHTS_n
static
Definition at line 49 of file VertexAttributeSemantics.h.
