CesiumGltf::InstanceAttributeSemantics Struct Reference
The standard glTF instance attribute semantics from EXT_mesh_gpu_instancing plus additional instance attribute semantics from extensions. More...
#include <CesiumGltf/InstanceAttributeSemantics.h>
static const std::string TRANSLATION
 XYZ translation vector.
static const std::string ROTATION
 XYZW rotation quaternion.
static const std::string SCALE
 XYZ scale vector.
static const std::array< std::string, 8 > FEATURE_ID_n
 Feature IDs used by EXT_instance_features.
Definition at line 13 of file InstanceAttributeSemantics.h.
◆ FEATURE_ID_n
const std::array<std::string, 8> CesiumGltf::InstanceAttributeSemantics::FEATURE_ID_n
static
Definition at line 32 of file InstanceAttributeSemantics.h.
◆ ROTATION
const std::string CesiumGltf::InstanceAttributeSemantics::ROTATION
static
Definition at line 22 of file InstanceAttributeSemantics.h.
◆ SCALE
const std::string CesiumGltf::InstanceAttributeSemantics::SCALE
static
XYZ scale vector.
Definition at line 27 of file InstanceAttributeSemantics.h.
◆ TRANSLATION
const std::string CesiumGltf::InstanceAttributeSemantics::TRANSLATION
static
Definition at line 17 of file InstanceAttributeSemantics.h.
