cesium-native 0.67.0
Options for decoding SPZ data. More...
#include <CesiumGltfReader/GltfReader.h>
| bool | forceFloatAccessors = false |
| If true, all accessors will be forced to use the FLOAT component type, regardless of the original data type. | |
| bool | applySigmoidToOpacity = true |
If true, the KHR_gaussian_splatting:OPACITY accessor will have the sigmoid function applied to its values. | |
| bool | preserveLogScaleValues = false |
If true, KHR_gaussian_splatting:SCALE values will be preserved in their logarithmic form, without applying any conversion. | |
Definition at line 30 of file GltfReader.h.
| bool CesiumGltfReader::SpzDecoderOptions::applySigmoidToOpacity = true |
Disabling this will pass the opacity values from spz directly to the glTF accessor. This setting does not affect the alpha component of COLOR_0, which will always have the transformation applied.
Definition at line 48 of file GltfReader.h.
| bool CesiumGltfReader::SpzDecoderOptions::forceFloatAccessors = false |
As the spz library outputs float data directly, this option can avoid unnecessary conversions to other component types.
Definition at line 38 of file GltfReader.h.
| bool CesiumGltfReader::SpzDecoderOptions::preserveLogScaleValues = false |
Definition at line 54 of file GltfReader.h.
