cesium-native 0.67.0
Metadata obtained from a glTF that describes the skirts present on the mesh. More...
#include <CesiumGltfContent/SkirtMeshMetadata.h>
| SkirtMeshMetadata () noexcept | |
Creates a new SkirtMeshMetadata with zeroes in all fields. | |
| static std::optional< SkirtMeshMetadata > | parseFromGltfExtras (const CesiumUtility::JsonValue::Object &extras) |
Parses SkirtMeshMetadata from the extras field of a glTF mesh, if present. | |
| static CesiumUtility::JsonValue::Object | createGltfExtras (const SkirtMeshMetadata &skirt) |
Creates a glTF mesh extras value from the provided SkirtMeshMetadata. | |
| uint32_t | noSkirtIndicesBegin |
| The start index of the range of a glTF mesh's indices buffer that should NOT be considered part of the skirt. | |
| uint32_t | noSkirtIndicesCount |
| The length of the range of a glTF mesh's indices buffer that should NOT be considered part of the skirt. | |
| uint32_t | noSkirtVerticesBegin |
| The start index of the range of a glTF mesh's vertices buffer that should NOT be considered part of the skirt. | |
| uint32_t | noSkirtVerticesCount |
| The length of the range of a glTF mesh's vertices buffer that should NOT be considered part of the skirt. | |
| glm::dvec3 | meshCenter |
| The center coordinates of the mesh, in Earth-Centered, Earth-Fixed Coordinates (ECEF). | |
| double | skirtWestHeight |
| The height of the skirt on the western edge of the mesh. | |
| double | skirtSouthHeight |
| The height of the skirt on the southern edge of the mesh. | |
| double | skirtEastHeight |
| The height of the skirt on the eastern edge of the mesh. | |
| double | skirtNorthHeight |
| The height of the skirt on the northern edge of the mesh. | |
SkirtMeshMetadata is attached to the glTF to allow Cesium Native to know which parts of the mesh are original and which contain the generated skirts, for operations such as creating texture coordinates for raster overlays. Definition at line 23 of file SkirtMeshMetadata.h.
inlinenoexcept |
Definition at line 27 of file SkirtMeshMetadata.h.
static |
This might be used when generating a glTF at runtime, in order to provide information on the mesh's skirts to the rest of Cesium Native.
| skirt | The skirt to create the glTF extras object from. |
static |
| extras | The extras field of the glTF mesh. |
SkirtMeshMetadata if it was present on the mesh. | glm::dvec3 CesiumGltfContent::SkirtMeshMetadata::meshCenter |
Definition at line 95 of file SkirtMeshMetadata.h.
| uint32_t CesiumGltfContent::SkirtMeshMetadata::noSkirtIndicesBegin |
Definition at line 67 of file SkirtMeshMetadata.h.
| uint32_t CesiumGltfContent::SkirtMeshMetadata::noSkirtIndicesCount |
Any indices outside of the range (noSkirtIndicesBegin, noSkirtIndicesBegin + noSkirtIndicesCount) will be considered part of the skirt.
Definition at line 76 of file SkirtMeshMetadata.h.
| uint32_t CesiumGltfContent::SkirtMeshMetadata::noSkirtVerticesBegin |
Definition at line 81 of file SkirtMeshMetadata.h.
| uint32_t CesiumGltfContent::SkirtMeshMetadata::noSkirtVerticesCount |
Any vertices outside of the range (noSkirtVerticesBegin, noSkirtVerticesBegin + noSkirtVerticesCount) will be considered part of the skirt.
Definition at line 90 of file SkirtMeshMetadata.h.
| double CesiumGltfContent::SkirtMeshMetadata::skirtEastHeight |
Definition at line 107 of file SkirtMeshMetadata.h.
| double CesiumGltfContent::SkirtMeshMetadata::skirtNorthHeight |
Definition at line 111 of file SkirtMeshMetadata.h.
| double CesiumGltfContent::SkirtMeshMetadata::skirtSouthHeight |
Definition at line 103 of file SkirtMeshMetadata.h.
| double CesiumGltfContent::SkirtMeshMetadata::skirtWestHeight |
Definition at line 99 of file SkirtMeshMetadata.h.
