CesiumUtility::TransformIterator< TTransformFunction, TIterator > Class Template Reference
An iterator that wraps another iterator and applies a transformation function to each element as it is accessed. More...
#include <CesiumUtility/TransformIterator.h>
Classes
struct  pointer
 A pointer to the type being iterated over. More...
Public Types
using iterator_category
 The iterator category tag denoting this iterator has the same category as the underlying iterator.
using value_type
 The type of value that is being iterated over, which is the result of the transformation function applied to the underlying iterator's value.
using difference_type
 The type used to identify distance between iterators, which for this iterator is the same as the underlying iterator's different_type.
 TransformIterator (TTransformFunction transformFunction, TIterator iterator)
 Creates a new instance.
value_type operator* () const
 Returns the current item being iterated. This applies the transformation function to the current item of the underlying iterator.
pointer operator-> () const
 Returns a pointer to the current item being iterated. This applies the transformation function to the current item of the underlying iterator.
TransformIterator & operator++ ()
 Advances the iterator to the next item (pre-incrementing).
TransformIterator operator++ (int)
 Advances the iterator to the next item (post-incrementing).
bool operator== (const TransformIterator &rhs) const
 Checks if two iterators are at the same item.
bool operator!= (const TransformIterator &other) const
 Checks if two iterators are NOT at the same item.
template<typename TTransformFunction, typename TIterator>
class CesiumUtility::TransformIterator< TTransformFunction, TIterator >
Definition at line 13 of file TransformIterator.h.
Member Typedef Documentation
◆ difference_type
using CesiumUtility::TransformIterator< TTransformFunction, TIterator >::difference_type
Initial value:
typename std::iterator_traits<TIterator>::difference_type
Definition at line 34 of file TransformIterator.h.
◆ iterator_category
using CesiumUtility::TransformIterator< TTransformFunction, TIterator >::iterator_category
Initial value:
typename std::iterator_traits<TIterator>::iterator_category
Definition at line 19 of file TransformIterator.h.
◆ value_type
using CesiumUtility::TransformIterator< TTransformFunction, TIterator >::value_type
Initial value:
typename std::invoke_result_t<
TTransformFunction,
typename std::iterator_traits<TIterator>::reference>
Definition at line 26 of file TransformIterator.h.
◆ TransformIterator()
CesiumUtility::TransformIterator< TTransformFunction, TIterator >::TransformIterator ( TTransformFunction transformFunction,
TIterator iterator )
transformFunctionThe function to apply to each element as it is accessed. This function must be callable with a single argument of the type being iterated over.
iteratorThe underlying iterator to wrap.
Definition at line 65 of file TransformIterator.h.
◆ operator!=()
bool CesiumUtility::TransformIterator< TTransformFunction, TIterator >::operator!= ( const TransformIterator< TTransformFunction, TIterator > & other) const
Definition at line 111 of file TransformIterator.h.
◆ operator*()
value_type CesiumUtility::TransformIterator< TTransformFunction, TIterator >::operator* ( ) const
Definition at line 72 of file TransformIterator.h.
◆ operator++() [1/2]
TransformIterator & CesiumUtility::TransformIterator< TTransformFunction, TIterator >::operator++ ( )
Definition at line 87 of file TransformIterator.h.
◆ operator++() [2/2]
TransformIterator CesiumUtility::TransformIterator< TTransformFunction, TIterator >::operator++ ( int )
Definition at line 95 of file TransformIterator.h.
◆ operator->()
pointer CesiumUtility::TransformIterator< TTransformFunction, TIterator >::operator-> ( ) const
Definition at line 80 of file TransformIterator.h.
◆ operator==()
bool CesiumUtility::TransformIterator< TTransformFunction, TIterator >::operator== ( const TransformIterator< TTransformFunction, TIterator > & rhs) const
Definition at line 104 of file TransformIterator.h.
