CesiumTilesetJsonReader::TilesetReader Class Reference
Reads Tileset instances from JSON. More...
#include <CesiumTilesetJsonReader/TilesetReader.h>
 TilesetReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Tileset > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Tileset from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Tileset > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Tileset from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Tileset > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Tileset from a rapidJson::Value.
Definition at line 24 of file TilesetReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Tileset > > CesiumTilesetJsonReader::TilesetReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Tileset > CesiumTilesetJsonReader::TilesetReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Tileset > CesiumTilesetJsonReader::TilesetReader::readFromJson ( const std::span< const std::byte > & data) const
