CesiumTilesetJsonReader::SubtreesReader Class Reference
Reads Subtrees instances from JSON. More...
#include <CesiumTilesetJsonReader/SubtreesReader.h>
 SubtreesReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtrees > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Subtrees from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtrees > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Subtrees from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Subtrees > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Subtrees from a rapidJson::Value.
Definition at line 24 of file SubtreesReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Subtrees > > CesiumTilesetJsonReader::SubtreesReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtrees > CesiumTilesetJsonReader::SubtreesReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtrees > CesiumTilesetJsonReader::SubtreesReader::readFromJson ( const std::span< const std::byte > & data) const
