CesiumTilesetJsonReader::PropertyStatisticsReader Class Reference
Reads PropertyStatistics instances from JSON. More...
#include <CesiumTilesetJsonReader/PropertyStatisticsReader.h>
 PropertyStatisticsReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::PropertyStatistics > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of PropertyStatistics from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::PropertyStatistics > readFromJson (const rapidjson::Value &value) const
 Reads an instance of PropertyStatistics from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::PropertyStatistics > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of PropertyStatistics from a rapidJson::Value.
Definition at line 25 of file PropertyStatisticsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::PropertyStatistics > > CesiumTilesetJsonReader::PropertyStatisticsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::PropertyStatistics > CesiumTilesetJsonReader::PropertyStatisticsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::PropertyStatistics > CesiumTilesetJsonReader::PropertyStatisticsReader::readFromJson ( const std::span< const std::byte > & data) const
