CesiumTilesetJsonReader::PaddingReader Class Reference
Reads Padding instances from JSON. More...
#include <CesiumTilesetJsonReader/PaddingReader.h>
 PaddingReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Padding > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Padding from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Padding > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Padding from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Padding > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Padding from a rapidJson::Value.
Definition at line 24 of file PaddingReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Padding > > CesiumTilesetJsonReader::PaddingReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Padding > CesiumTilesetJsonReader::PaddingReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Padding > CesiumTilesetJsonReader::PaddingReader::readFromJson ( const std::span< const std::byte > & data) const
