cesium-native 0.67.0
Reads ExtensionSchemaMaxarContentGeoJsonGeometryValue instances from JSON. More...
#include <CesiumTilesetJsonReader/ExtensionSchemaMaxarContentGeoJsonGeometryValueReader.h>
| ExtensionSchemaMaxarContentGeoJsonGeometryValueReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionSchemaMaxarContentGeoJsonGeometryValue from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionSchemaMaxarContentGeoJsonGeometryValue from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionSchemaMaxarContentGeoJsonGeometryValue from a rapidJson::Value. | |
Definition at line 26 of file ExtensionSchemaMaxarContentGeoJsonGeometryValueReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue > > CesiumTilesetJsonReader::ExtensionSchemaMaxarContentGeoJsonGeometryValueReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue > CesiumTilesetJsonReader::ExtensionSchemaMaxarContentGeoJsonGeometryValueReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue > CesiumTilesetJsonReader::ExtensionSchemaMaxarContentGeoJsonGeometryValueReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
