cesium-native 0.67.0
Reads Extension3dTilesContentConditionalDimensionsValue instances from JSON. More...
#include <CesiumTilesetJsonReader/Extension3dTilesContentConditionalDimensionsValueReader.h>
| Extension3dTilesContentConditionalDimensionsValueReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Extension3dTilesContentConditionalDimensionsValue from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Extension3dTilesContentConditionalDimensionsValue from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Extension3dTilesContentConditionalDimensionsValue from a rapidJson::Value. | |
Definition at line 26 of file Extension3dTilesContentConditionalDimensionsValueReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue > > CesiumTilesetJsonReader::Extension3dTilesContentConditionalDimensionsValueReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue > CesiumTilesetJsonReader::Extension3dTilesContentConditionalDimensionsValueReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditionalDimensionsValue > CesiumTilesetJsonReader::Extension3dTilesContentConditionalDimensionsValueReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
