CesiumTilesetJsonReader::ConditionalContentItemReader Class Reference
Reads ConditionalContentItem instances from JSON. More...
#include <CesiumTilesetJsonReader/ConditionalContentItemReader.h>
 ConditionalContentItemReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContentItem > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ConditionalContentItem from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContentItem > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ConditionalContentItem from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ConditionalContentItem > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ConditionalContentItem from a rapidJson::Value.
Definition at line 25 of file ConditionalContentItemReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ConditionalContentItem > > CesiumTilesetJsonReader::ConditionalContentItemReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContentItem > CesiumTilesetJsonReader::ConditionalContentItemReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContentItem > CesiumTilesetJsonReader::ConditionalContentItemReader::readFromJson ( const std::span< const std::byte > & data) const
