CesiumTilesetJsonReader::BufferReader Class Reference
Reads Buffer instances from JSON. More...
#include <CesiumTilesetJsonReader/BufferReader.h>
 BufferReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Buffer > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Buffer from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Buffer > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Buffer from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Buffer > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Buffer from a rapidJson::Value.
Definition at line 24 of file BufferReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Buffer > > CesiumTilesetJsonReader::BufferReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Buffer > CesiumTilesetJsonReader::BufferReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Buffer > CesiumTilesetJsonReader::BufferReader::readFromJson ( const std::span< const std::byte > & data) const
