cesium-native 0.67.0
Reads Availability instances from JSON. More...
#include <CesiumTilesetJsonReader/AvailabilityReader.h>
| AvailabilityReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Availability > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Availability from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Availability > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Availability from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Availability > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Availability from a rapidJson::Value. | |
Definition at line 25 of file AvailabilityReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Availability > > CesiumTilesetJsonReader::AvailabilityReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Availability > CesiumTilesetJsonReader::AvailabilityReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Availability > CesiumTilesetJsonReader::AvailabilityReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
