CesiumJsonReader::JsonReader Class Reference
Reads JSON. More...
#include <CesiumJsonReader/JsonReader.h>
static ReadJsonResult< typename T::ValueType > readJson (const std::span< const std::byte > &data, T &handler)
 Reads JSON from a byte buffer into a statically-typed class.
static ReadJsonResult< typename T::ValueType > readJson (const rapidjson::Value &jsonValue, T &handler)
 Reads JSON from a rapidjson::Value into a statically-typed class.
Reads JSON.
Definition at line 43 of file JsonReader.h.
◆ readJson() [1/2]
static ReadJsonResult< typename T::ValueType > CesiumJsonReader::JsonReader::readJson ( const rapidjson::Value & jsonValue,
T & handler )
inlinestatic
jsonValueThe rapidjson::Value from which to read JSON.
handlerThe handler to receive the top-level JSON object. This instance must:
  • Implement IJsonHandler.
  • Contain a ValueType type alias indicating the type of the instance to be read into.
  • Have a reset method taking 1) a parent IJsonHandler pointer, and 2) and a pointer to a value of type ValueType.
The result of reading the JSON.
Definition at line 97 of file JsonReader.h.
◆ readJson() [2/2]
static ReadJsonResult< typename T::ValueType > CesiumJsonReader::JsonReader::readJson ( const std::span< const std::byte > & data,
T & handler )
inlinestatic
dataThe buffer from which to read JSON.
Definition at line 60 of file JsonReader.h.
