CesiumITwinClient::AuthenticationToken Class Reference
An authentication token obtained from the iTwin OAuth2 flow. More...
#include <CesiumITwinClient/AuthenticationToken.h>
bool isValid () const
 Is this token currently valid?
int64_t getExpirationTime () const
 Returns the number of seconds since the Unix epoch representing the time that this token expires.
const std::string & getToken () const
 Returns the contained token string.
std::string getTokenHeader () const
 Returns the HTTP Authorization header for this token.
 AuthenticationToken (const std::string &token, std::string &&name, std::string &&userName, std::vector< std::string > &&scopes, int64_t notValidBefore, int64_t expires)
 Creates a new AuthenticationToken for an access token.
 AuthenticationToken (const std::string &token, std::string &&iTwinId, int64_t expires)
 Creates a new AuthenticationToken for a share token.
static CesiumUtility::Result< AuthenticationToken > parse (const std::string &tokenStr)
 Creates a new AuthenticationToken by parsing the provided JWT authentication token.
Definition at line 17 of file AuthenticationToken.h.
◆ AuthenticationToken() [1/2]
CesiumITwinClient::AuthenticationToken::AuthenticationToken ( const std::string & token,
std::string && name,
std::string && userName,
std::vector< std::string > && scopes,
int64_t expires )
This constructor assumes all the data in the provided token has already been parsed. If not, you should call parse instead.
tokenThe full token string.
nameThe name of the token.
userNameThe name of the user this token belongs to.
scopesThe set of scopes this token is valid for.
notValidBeforeA UNIX timestamp representing the point in time that this token starts to be valid.
expiresA UNIX timestamp representing the point in time that this token stops being valid.
◆ AuthenticationToken() [2/2]
std::string && iTwinId,
int64_t expires )
iTwinIdThe ID of the iTwin this share token provides access to.
Definition at line 91 of file AuthenticationToken.h.
◆ getExpirationTime()
int64_t CesiumITwinClient::AuthenticationToken::getExpirationTime ( ) const
Definition at line 42 of file AuthenticationToken.h.
◆ getToken()
const std::string & CesiumITwinClient::AuthenticationToken::getToken ( ) const
Definition at line 47 of file AuthenticationToken.h.
◆ getTokenHeader()
std::string CesiumITwinClient::AuthenticationToken::getTokenHeader ( ) const
Access tokens use a Bearer header while share tokens use a Basic header.
◆ isValid()
bool CesiumITwinClient::AuthenticationToken::isValid ( ) const
For the token to be valid, it must currently be after its "not valid before" date but before its expiration date.
◆ parse()
static CesiumUtility::Result< AuthenticationToken > CesiumITwinClient::AuthenticationToken::parse ( const std::string & tokenStr)
static
tokenStrThe JWT authentication token.
A Result containing either the parsed AuthenticationToken or error messages.
