CesiumGltfReader::TextureReader Class Reference
Reads Texture instances from JSON. More...
#include <CesiumGltfReader/TextureReader.h>
 TextureReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Texture > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Texture from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Texture > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Texture from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Texture > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Texture from a rapidJson::Value.
Definition at line 24 of file TextureReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Texture > > CesiumGltfReader::TextureReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Texture > CesiumGltfReader::TextureReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Texture > CesiumGltfReader::TextureReader::readFromJson ( const std::span< const std::byte > & data) const
