CesiumGltfReader::TextureInfoReader Class Reference
Reads TextureInfo instances from JSON. More...
#include <CesiumGltfReader/TextureInfoReader.h>
 TextureInfoReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::TextureInfo > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of TextureInfo from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::TextureInfo > readFromJson (const rapidjson::Value &value) const
 Reads an instance of TextureInfo from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::TextureInfo > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of TextureInfo from a rapidJson::Value.
Definition at line 24 of file TextureInfoReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::TextureInfo > > CesiumGltfReader::TextureInfoReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::TextureInfo > CesiumGltfReader::TextureInfoReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::TextureInfo > CesiumGltfReader::TextureInfoReader::readFromJson ( const std::span< const std::byte > & data) const
