CesiumGltfReader::SkinReader Class Reference
Reads Skin instances from JSON. More...
#include <CesiumGltfReader/SkinReader.h>
 SkinReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Skin > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Skin from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Skin > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Skin from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Skin > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Skin from a rapidJson::Value.
Definition at line 24 of file SkinReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Skin > > CesiumGltfReader::SkinReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Skin > CesiumGltfReader::SkinReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Skin > CesiumGltfReader::SkinReader::readFromJson ( const std::span< const std::byte > & data) const
