CesiumGltfReader::ShapeReader Class Reference
Reads Shape instances from JSON. More...
#include <CesiumGltfReader/ShapeReader.h>
 ShapeReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Shape > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Shape from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Shape > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Shape from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Shape > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Shape from a rapidJson::Value.
Definition at line 24 of file ShapeReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Shape > > CesiumGltfReader::ShapeReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Shape > CesiumGltfReader::ShapeReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Shape > CesiumGltfReader::ShapeReader::readFromJson ( const std::span< const std::byte > & data) const
