CesiumGltfReader::SchemaReader Class Reference
Reads Schema instances from JSON. More...
#include <CesiumGltfReader/SchemaReader.h>
 SchemaReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Schema > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Schema from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Schema > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Schema from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Schema > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Schema from a rapidJson::Value.
Definition at line 24 of file SchemaReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Schema > > CesiumGltfReader::SchemaReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Schema > CesiumGltfReader::SchemaReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Schema > CesiumGltfReader::SchemaReader::readFromJson ( const std::span< const std::byte > & data) const
