CesiumGltfReader::SamplerReader Class Reference
Reads Sampler instances from JSON. More...
#include <CesiumGltfReader/SamplerReader.h>
 SamplerReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sampler > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Sampler from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sampler > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Sampler from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Sampler > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Sampler from a rapidJson::Value.
Definition at line 24 of file SamplerReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Sampler > > CesiumGltfReader::SamplerReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sampler > CesiumGltfReader::SamplerReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sampler > CesiumGltfReader::SamplerReader::readFromJson ( const std::span< const std::byte > & data) const
