CesiumGltfReader::PropertyTexturePropertyReader Class Reference
Reads PropertyTextureProperty instances from JSON. More...
#include <CesiumGltfReader/PropertyTexturePropertyReader.h>
 PropertyTexturePropertyReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyTextureProperty > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of PropertyTextureProperty from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyTextureProperty > readFromJson (const rapidjson::Value &value) const
 Reads an instance of PropertyTextureProperty from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::PropertyTextureProperty > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of PropertyTextureProperty from a rapidJson::Value.
Definition at line 25 of file PropertyTexturePropertyReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::PropertyTextureProperty > > CesiumGltfReader::PropertyTexturePropertyReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyTextureProperty > CesiumGltfReader::PropertyTexturePropertyReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyTextureProperty > CesiumGltfReader::PropertyTexturePropertyReader::readFromJson ( const std::span< const std::byte > & data) const
