CesiumGltfReader::PropertyAttributePropertyReader Class Reference
Reads PropertyAttributeProperty instances from JSON. More...
#include <CesiumGltfReader/PropertyAttributePropertyReader.h>
 PropertyAttributePropertyReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyAttributeProperty > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of PropertyAttributeProperty from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyAttributeProperty > readFromJson (const rapidjson::Value &value) const
 Reads an instance of PropertyAttributeProperty from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::PropertyAttributeProperty > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of PropertyAttributeProperty from a rapidJson::Value.
Definition at line 25 of file PropertyAttributePropertyReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::PropertyAttributeProperty > > CesiumGltfReader::PropertyAttributePropertyReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyAttributeProperty > CesiumGltfReader::PropertyAttributePropertyReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::PropertyAttributeProperty > CesiumGltfReader::PropertyAttributePropertyReader::readFromJson ( const std::span< const std::byte > & data) const
