CesiumGltfReader::PlaneReader Class Reference
Reads Plane instances from JSON. More...
#include <CesiumGltfReader/PlaneReader.h>
 PlaneReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Plane > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Plane from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Plane > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Plane from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Plane > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Plane from a rapidJson::Value.
Definition at line 24 of file PlaneReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Plane > > CesiumGltfReader::PlaneReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Plane > CesiumGltfReader::PlaneReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Plane > CesiumGltfReader::PlaneReader::readFromJson ( const std::span< const std::byte > & data) const
