Reads Padding instances from JSON. More...
#include <CesiumGltfReader/PaddingReader.h>
| PaddingReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Padding > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Padding from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Padding > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Padding from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Padding > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Padding from a rapidJson::Value. | |
Definition at line 24 of file PaddingReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Padding > > CesiumGltfReader::PaddingReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Padding > CesiumGltfReader::PaddingReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Padding > CesiumGltfReader::PaddingReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
