CesiumGltfReader::ModelReader Class Reference
Reads Model instances from JSON. More...
#include <CesiumGltfReader/ModelReader.h>
 ModelReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Model > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Model from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Model > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Model from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Model > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Model from a rapidJson::Value.
Definition at line 24 of file ModelReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Model > > CesiumGltfReader::ModelReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Model > CesiumGltfReader::ModelReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Model > CesiumGltfReader::ModelReader::readFromJson ( const std::span< const std::byte > & data) const
