CesiumGltfReader::MaterialReader Class Reference
Reads Material instances from JSON. More...
#include <CesiumGltfReader/MaterialReader.h>
 MaterialReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Material > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Material from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Material > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Material from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Material > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Material from a rapidJson::Value.
Definition at line 24 of file MaterialReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Material > > CesiumGltfReader::MaterialReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Material > CesiumGltfReader::MaterialReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Material > CesiumGltfReader::MaterialReader::readFromJson ( const std::span< const std::byte > & data) const
