CesiumGltfReader::MaterialNormalTextureInfoReader Class Reference
Reads MaterialNormalTextureInfo instances from JSON. More...
#include <CesiumGltfReader/MaterialNormalTextureInfoReader.h>
 MaterialNormalTextureInfoReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::MaterialNormalTextureInfo > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of MaterialNormalTextureInfo from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::MaterialNormalTextureInfo > readFromJson (const rapidjson::Value &value) const
 Reads an instance of MaterialNormalTextureInfo from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::MaterialNormalTextureInfo > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of MaterialNormalTextureInfo from a rapidJson::Value.
Definition at line 25 of file MaterialNormalTextureInfoReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::MaterialNormalTextureInfo > > CesiumGltfReader::MaterialNormalTextureInfoReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::MaterialNormalTextureInfo > CesiumGltfReader::MaterialNormalTextureInfoReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::MaterialNormalTextureInfo > CesiumGltfReader::MaterialNormalTextureInfoReader::readFromJson ( const std::span< const std::byte > & data) const
