CesiumGltfReader::LightReader Class Reference
Reads Light instances from JSON. More...
#include <CesiumGltfReader/LightReader.h>
 LightReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Light > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Light from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Light > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Light from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Light > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Light from a rapidJson::Value.
Definition at line 24 of file LightReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Light > > CesiumGltfReader::LightReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Light > CesiumGltfReader::LightReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Light > CesiumGltfReader::LightReader::readFromJson ( const std::span< const std::byte > & data) const
