CesiumGltfReader::LayerReader Class Reference
Reads Layer instances from JSON. More...
#include <CesiumGltfReader/LayerReader.h>
 LayerReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Layer > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Layer from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Layer > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Layer from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Layer > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Layer from a rapidJson::Value.
Definition at line 24 of file LayerReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Layer > > CesiumGltfReader::LayerReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Layer > CesiumGltfReader::LayerReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Layer > CesiumGltfReader::LayerReader::readFromJson ( const std::span< const std::byte > & data) const
