CesiumGltfReader::FileReader Class Reference
Reads File instances from JSON. More...
#include <CesiumGltfReader/FileReader.h>
 FileReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::File > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of File from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::File > readFromJson (const rapidjson::Value &value) const
 Reads an instance of File from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::File > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of File from a rapidJson::Value.
Definition at line 24 of file FileReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::File > > CesiumGltfReader::FileReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::File > CesiumGltfReader::FileReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::File > CesiumGltfReader::FileReader::readFromJson ( const std::span< const std::byte > & data) const
