CesiumGltfReader::FeatureIdTextureReader Class Reference
Reads FeatureIdTexture instances from JSON. More...
#include <CesiumGltfReader/FeatureIdTextureReader.h>
 FeatureIdTextureReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::FeatureIdTexture > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of FeatureIdTexture from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::FeatureIdTexture > readFromJson (const rapidjson::Value &value) const
 Reads an instance of FeatureIdTexture from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::FeatureIdTexture > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of FeatureIdTexture from a rapidJson::Value.
Definition at line 25 of file FeatureIdTextureReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::FeatureIdTexture > > CesiumGltfReader::FeatureIdTextureReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::FeatureIdTexture > CesiumGltfReader::FeatureIdTextureReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::FeatureIdTexture > CesiumGltfReader::FeatureIdTextureReader::readFromJson ( const std::span< const std::byte > & data) const
