CesiumGltfReader::ExtensionTextureWebpReader Class Reference
Reads ExtensionTextureWebp instances from JSON. More...
#include <CesiumGltfReader/ExtensionTextureWebpReader.h>
 ExtensionTextureWebpReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionTextureWebp > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionTextureWebp from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionTextureWebp > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionTextureWebp from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionTextureWebp > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionTextureWebp from a rapidJson::Value.
Definition at line 25 of file ExtensionTextureWebpReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionTextureWebp > > CesiumGltfReader::ExtensionTextureWebpReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionTextureWebp > CesiumGltfReader::ExtensionTextureWebpReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionTextureWebp > CesiumGltfReader::ExtensionTextureWebpReader::readFromJson ( const std::span< const std::byte > & data) const
