CesiumGltfReader::ExtensionNodeMaxarMeshVariantsReader Class Reference
Reads ExtensionNodeMaxarMeshVariants instances from JSON. More...
#include <CesiumGltfReader/ExtensionNodeMaxarMeshVariantsReader.h>
 ExtensionNodeMaxarMeshVariantsReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariants > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionNodeMaxarMeshVariants from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariants > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionNodeMaxarMeshVariants from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionNodeMaxarMeshVariants > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionNodeMaxarMeshVariants from a rapidJson::Value.
Definition at line 25 of file ExtensionNodeMaxarMeshVariantsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionNodeMaxarMeshVariants > > CesiumGltfReader::ExtensionNodeMaxarMeshVariantsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariants > CesiumGltfReader::ExtensionNodeMaxarMeshVariantsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariants > CesiumGltfReader::ExtensionNodeMaxarMeshVariantsReader::readFromJson ( const std::span< const std::byte > & data) const
