Reads ExtensionNodeMaxarMeshVariantsMappingsValue instances from JSON. More...
#include <CesiumGltfReader/ExtensionNodeMaxarMeshVariantsMappingsValueReader.h>
| ExtensionNodeMaxarMeshVariantsMappingsValueReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionNodeMaxarMeshVariantsMappingsValue from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionNodeMaxarMeshVariantsMappingsValue from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionNodeMaxarMeshVariantsMappingsValue from a rapidJson::Value. | |
Definition at line 25 of file ExtensionNodeMaxarMeshVariantsMappingsValueReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > > CesiumGltfReader::ExtensionNodeMaxarMeshVariantsMappingsValueReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > CesiumGltfReader::ExtensionNodeMaxarMeshVariantsMappingsValueReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > CesiumGltfReader::ExtensionNodeMaxarMeshVariantsMappingsValueReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
