CesiumGltfReader::ExtensionNode3dTilesTilesetReader Class Reference
Reads ExtensionNode3dTilesTileset instances from JSON. More...
#include <CesiumGltfReader/ExtensionNode3dTilesTilesetReader.h>
 ExtensionNode3dTilesTilesetReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNode3dTilesTileset > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionNode3dTilesTileset from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNode3dTilesTileset > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionNode3dTilesTileset from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionNode3dTilesTileset > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionNode3dTilesTileset from a rapidJson::Value.
Definition at line 25 of file ExtensionNode3dTilesTilesetReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionNode3dTilesTileset > > CesiumGltfReader::ExtensionNode3dTilesTilesetReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNode3dTilesTileset > CesiumGltfReader::ExtensionNode3dTilesTilesetReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionNode3dTilesTileset > CesiumGltfReader::ExtensionNode3dTilesTilesetReader::readFromJson ( const std::span< const std::byte > & data) const
