CesiumGltfReader::ExtensionModelMaxarMeshVariantsValueReader Class Reference
Reads ExtensionModelMaxarMeshVariantsValue instances from JSON. More...
#include <CesiumGltfReader/ExtensionModelMaxarMeshVariantsValueReader.h>
 ExtensionModelMaxarMeshVariantsValueReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionModelMaxarMeshVariantsValue from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionModelMaxarMeshVariantsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionModelMaxarMeshVariantsValue from a rapidJson::Value.
Definition at line 25 of file ExtensionModelMaxarMeshVariantsValueReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > > CesiumGltfReader::ExtensionModelMaxarMeshVariantsValueReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > CesiumGltfReader::ExtensionModelMaxarMeshVariantsValueReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > CesiumGltfReader::ExtensionModelMaxarMeshVariantsValueReader::readFromJson ( const std::span< const std::byte > & data) const
