CesiumGltfReader::ExtensionModelExtStructuralMetadataReader Class Reference
Reads ExtensionModelExtStructuralMetadata instances from JSON. More...
#include <CesiumGltfReader/ExtensionModelExtStructuralMetadataReader.h>
 ExtensionModelExtStructuralMetadataReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtStructuralMetadata > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionModelExtStructuralMetadata from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtStructuralMetadata > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionModelExtStructuralMetadata from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelExtStructuralMetadata > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionModelExtStructuralMetadata from a rapidJson::Value.
Definition at line 25 of file ExtensionModelExtStructuralMetadataReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelExtStructuralMetadata > > CesiumGltfReader::ExtensionModelExtStructuralMetadataReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtStructuralMetadata > CesiumGltfReader::ExtensionModelExtStructuralMetadataReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtStructuralMetadata > CesiumGltfReader::ExtensionModelExtStructuralMetadataReader::readFromJson ( const std::span< const std::byte > & data) const
