Reads ExtensionModelExtNodeVisibilityConditionsDimensionsValue instances from JSON. More...
#include <CesiumGltfReader/ExtensionModelExtNodeVisibilityConditionsDimensionsValueReader.h>
| ExtensionModelExtNodeVisibilityConditionsDimensionsValueReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionModelExtNodeVisibilityConditionsDimensionsValue from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionModelExtNodeVisibilityConditionsDimensionsValue from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionModelExtNodeVisibilityConditionsDimensionsValue from a rapidJson::Value. | |
Definition at line 27 of file ExtensionModelExtNodeVisibilityConditionsDimensionsValueReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > > CesiumGltfReader::ExtensionModelExtNodeVisibilityConditionsDimensionsValueReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > CesiumGltfReader::ExtensionModelExtNodeVisibilityConditionsDimensionsValueReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > CesiumGltfReader::ExtensionModelExtNodeVisibilityConditionsDimensionsValueReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
