CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsReader Class Reference
Reads ExtensionMeshPrimitiveKhrMaterialsVariants instances from JSON. More...
#include <CesiumGltfReader/ExtensionMeshPrimitiveKhrMaterialsVariantsReader.h>
 ExtensionMeshPrimitiveKhrMaterialsVariantsReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionMeshPrimitiveKhrMaterialsVariants from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionMeshPrimitiveKhrMaterialsVariants from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionMeshPrimitiveKhrMaterialsVariants from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants > > CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants > CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants > CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsReader::readFromJson ( const std::span< const std::byte > & data) const
