CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValueReader Class Reference
Reads ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue instances from JSON. More...
#include <CesiumGltfReader/ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValueReader.h>
 ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValueReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > > CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValueReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValueReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > CesiumGltfReader::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValueReader::readFromJson ( const std::span< const std::byte > & data) const
