Reads ExtensionMeshPrimitiveExtStructuralMetadata instances from JSON. More...
#include <CesiumGltfReader/ExtensionMeshPrimitiveExtStructuralMetadataReader.h>
| ExtensionMeshPrimitiveExtStructuralMetadataReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionMeshPrimitiveExtStructuralMetadata from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionMeshPrimitiveExtStructuralMetadata from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionMeshPrimitiveExtStructuralMetadata from a rapidJson::Value. | |
Definition at line 25 of file ExtensionMeshPrimitiveExtStructuralMetadataReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata > > CesiumGltfReader::ExtensionMeshPrimitiveExtStructuralMetadataReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata > CesiumGltfReader::ExtensionMeshPrimitiveExtStructuralMetadataReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata > CesiumGltfReader::ExtensionMeshPrimitiveExtStructuralMetadataReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
