Reads ExtensionMaterialBentleyMaterialsLineStyle instances from JSON. More...
#include <CesiumGltfReader/ExtensionMaterialBentleyMaterialsLineStyleReader.h>
| ExtensionMaterialBentleyMaterialsLineStyleReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionMaterialBentleyMaterialsLineStyle from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionMaterialBentleyMaterialsLineStyle from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionMaterialBentleyMaterialsLineStyle from a rapidJson::Value. | |
Definition at line 25 of file ExtensionMaterialBentleyMaterialsLineStyleReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle > > CesiumGltfReader::ExtensionMaterialBentleyMaterialsLineStyleReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle > CesiumGltfReader::ExtensionMaterialBentleyMaterialsLineStyleReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMaterialBentleyMaterialsLineStyle > CesiumGltfReader::ExtensionMaterialBentleyMaterialsLineStyleReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
