CesiumGltfReader::ExtensionKhrTextureTransformReader Class Reference
Reads ExtensionKhrTextureTransform instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrTextureTransformReader.h>
 ExtensionKhrTextureTransformReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrTextureTransform > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrTextureTransform from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrTextureTransform > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrTextureTransform from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrTextureTransform > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrTextureTransform from a rapidJson::Value.
Definition at line 25 of file ExtensionKhrTextureTransformReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrTextureTransform > > CesiumGltfReader::ExtensionKhrTextureTransformReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrTextureTransform > CesiumGltfReader::ExtensionKhrTextureTransformReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrTextureTransform > CesiumGltfReader::ExtensionKhrTextureTransformReader::readFromJson ( const std::span< const std::byte > & data) const
