CesiumGltfReader::ExtensionKhrMaterialsUnlitReader Class Reference
Reads ExtensionKhrMaterialsUnlit instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrMaterialsUnlitReader.h>
 ExtensionKhrMaterialsUnlitReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrMaterialsUnlit > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrMaterialsUnlit from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrMaterialsUnlit > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrMaterialsUnlit from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrMaterialsUnlit > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrMaterialsUnlit from a rapidJson::Value.
Definition at line 25 of file ExtensionKhrMaterialsUnlitReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrMaterialsUnlit > > CesiumGltfReader::ExtensionKhrMaterialsUnlitReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrMaterialsUnlit > CesiumGltfReader::ExtensionKhrMaterialsUnlitReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrMaterialsUnlit > CesiumGltfReader::ExtensionKhrMaterialsUnlitReader::readFromJson ( const std::span< const std::byte > & data) const
