Reads ExtensionKhrImplicitShapesCapsule instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrImplicitShapesCapsuleReader.h>
| ExtensionKhrImplicitShapesCapsuleReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesCapsule > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionKhrImplicitShapesCapsule from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesCapsule > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionKhrImplicitShapesCapsule from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrImplicitShapesCapsule > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionKhrImplicitShapesCapsule from a rapidJson::Value. | |
Definition at line 25 of file ExtensionKhrImplicitShapesCapsuleReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrImplicitShapesCapsule > > CesiumGltfReader::ExtensionKhrImplicitShapesCapsuleReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesCapsule > CesiumGltfReader::ExtensionKhrImplicitShapesCapsuleReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesCapsule > CesiumGltfReader::ExtensionKhrImplicitShapesCapsuleReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
